Hi Daniel, model dx103sk Electrolux I am getting water hammer through copper pipes every time dishwasher water valve opens and closes I have changed 3 types of anti hammer washers on supply tap. also changed the one way water valve at hot water service next I am looking at changing the pressure valve next to the dishwasher as this problem really on happen when I changed brands of dishwasher. ? kpa rating do you think I should use? Am I going down the right path here? thanks David Desira
There are several reasons that a washing machine,or dishwasher won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes. 1 A dishwasher won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem. 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place. 3 Loose or broken belts could also prevent a dishwasher from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task. 4 Another possibility for a dishwasher to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin. 5 If all of the above steps fail to produce a dishwasher that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected.
Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot.
Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected.
In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
(pre-typed- I don't type that fast!)
John C
John C
Behind the dishwasher there is normally a two little taps 1 for cold water and 1 for hot water, check that the taps are turned the right way and are letting the water into the mechine. post back what you find.
