The bamboo flooring is most popular now and also a good alternative to traditional hardwood flooring. As bamboo belongs to grass family, the main benefit of bamboo is its ability to regenerate so quickly.
For eco-friendly flooring bamboo is the great choice. There are some other advantages too.
Bamboo is easily available in offline stores and also in online stores.
It is true that hardwood flooring gives the natural feel and elegant look, also expensive. The bamboo flooring has its unique beauty.
Unique beauty: The natural striations in the bamboo give the floors a unique beauty that is attractive in any room. Bamboo floors will look as attractive in 15 years as they do the day you install them.
Bamboo is flexible. Despite the consequences of your existing room's furnishing and d?cor, you are bound to find a shade of bamboo that compliments it beautifully. There are such a huge selection of bamboo planks, you can install it in your complete house and have different looks.
Durability of bamboo is also high. You can install Bamboo flooring in high traffic areas of your home. Strand woven bamboo has a Janka hardness rating almost 3 times harder than oak - now that's durable! Bamboo floors are so strong and durable with 25 year warranty (approximately).
Bamboo is inexpensive. If you compare to traditional hardwood floors, you will get bamboo at very reasonable price. So it is a great choice for low budget home d?cor.
Bamboo installation is very easy. By using the floating floor method, most homeowners would be able to install floors in a room of their home over a weekend.
Bamboo is Moisture Resistant. The main advantage of bamboo flooring over solid wood is the moisture resistant, which makes bamboo a superior flooring choice for kitchens and powder rooms. If you choose hardwood flooring for kitchen or in moist area, you can do hardwood floor refinishing with polyurethane coating to make it moist resistant.
Bamboo flooring is also resistant to allergen and bugs. Fiber-based bamboo floors are not only easier to clean but are resistant to bug invasions and do not catch allergens like hardwood floors do.
The main advantages of bamboo flooring are its durability,
and the fact that it is sourced from a renewable resource. Moreover, bamboo
flooring is much more resistant to expansions than solid wood and is also
insect resistant.
Absolutely, just like hardwood and laminated floors you need
to acclimate the floor before you install it although bamboo floor is much more
resistant to expansions and acclimate better to temperature and humidity
changes.
Bamboo flooring is much more resistant to moisture than most solid hardwoods. you should still never leave liquid on it for an extended period of time in order to protect your floor.
Horizontal strips are glued together horizontally and show the bamboo's nodes in the flooring. Vertical strips are stacked vertically and glued together, giving the floor a more uniform appearance without any nodes.
Bamboo floor doesn't have many disadvantages although there
are some manufacturers that use high-formaldehyde glues to bind the flooring
together which is not advised. You should only purchase flooring that complies
with E1 Safety Standards.
Bamboo flooring is flattened first, and then boiled in order to remove starch, dried, and glued together under high pressure into planks. They are then sanded and stained, varnished, or used as is.
