1998 Chevrolet C1500 Logo
Posted on Feb 03, 2009
Broken Door Handle on 1998 Chevrolet C1500 PU
The driver door handle broke on my 1998 Chevrolet C1500 PU. I need to know how to remove the door panel as well as instructions to replace the handle itself. I don't want to break anything 'cause I don't know what I'm doing.
  • Anonymous Mar 12, 2014
    replace flasher switch on 1998 chevrolet c1500
    replace flasher switch on 1998 Chevrolet c1500 truck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
672
Points
Carefully use a screwdriver or chisel to pry the interior panel off of the door...it's thin, like an upholstered piece of hard board, held on by plastic ribbed push-studs, every so often. Those studs can be pryed out and pushed in to reinstall many times if you're careful but I did manage to break one on my truck. Of course there is also a couple of screws near the door handle as I recall but they are visible. A small piece of triangular shaped plastic must also be popped / pryed off of the forward window area. I'm drinking right now, but I think you may have to drill out a rivet to remove the old handle assembly but it is really easy, just pick a drill bit about the same diameter as the rivet and drill it till it falls apart. Install the new assembly with a pop rivet of your own. good luck
How do you replace the driver's side door handle on a 1998 VW Jetta
There is only one screw holding the door handle in, the screw is right on the inside of the door. Its right above where the door attaches to the door.
1helpful
1998 Isuzu Rodeo Drivers Outside Door Handle doesn't work
The door skin needs to be removed you will need 1/4" drive ratchet, extensions, metric box end wrenches, a long needle nose pliers, screw drivers,a pro pick set and some mechanical ability, verify the linkage is intact, if it is you probably have a broken handle, if the outer handle is broke E-Bay has them new and used or you can go the dealer route. the time to repair is usually 1 to 2 hours. GL
3helpful
2answers
Drivers door won't open from inside vehicle, opens from outside with no problem.
you may have a broken inside handle, open the door, remove screws holding door panel on,then pry door panel off, it has plastic retainers that hold panel on they pry off and pop back when installing panel, once the panel is off you will see if the rod just came off or if handle broke if its the handle replace it remove screww holding it and install new one, some are held with revits, drill revit to remove,use screws to reinstall. hope this helps.
The driver door will not open from the inside. Only the handle on the outside works. 1998 c1500 silverado
take off door panel probable needs inner door handle assy can get from auto wrecker or dealer made of plastic and the tab breaks off not allowing the door to open
4helpful
How do you take off a rear door panel 05 chev pu
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
4helpful
How do you change the interior drivers door handle on a 1998
You'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and then unhook the rod attached to the handle lever and reverse to put on...
2answers
How to replace inside door handle on passenger on 1998 chevy silv
Remove screw from inside door grab handle. Remove door panel by carefully prying out plastic clips. Drill or chisel off pop rivets holding the handle on. Pull handle out far enough to disconnect linkage and remove handle. Install new handle and secure to metal panel with new pop rivets or sheet metal screws. It may be easier to reconnect linkages by removing the metal panel also.
3helpful
How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
DRIVERS SIDE DOOR WILL NOT OPEN WITH OUTSIDE DOOR HANDEL?
Broken linkage connecter at handle or latch, you have to remove the door panel for access. It is possible the actaul handle is broken where the linkage attaches.
1helpful
2answers
Door handle repair
Then you'll have to remove the inside door skin. It's not too difficult. The hardest part is if you have manual rollup windows, you need to remove a clip behind the window crank and sometimes it will fly off and get lost. Remove all screws you can find (some are behind plastic covers, like for the inside door opening handle, after removing that one slide it to the front of the car to remove the handle), one or more may be hidden under the bottom carpeted area if you have that (run your fingers around the edge area to feel the holes). After all that the door skin should be held on by 'panel pops' sometimes these break if the cars old or if your not carefull. You can get replacements cheaply enough.
If you need anymore help let me know.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
