Rolex Datejust SS Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone have a manual for a datejust rolex
Just purchased a previousley owned rolex datejust just wondered if there was a downloadable manual available
  • adgj99979 Feb 12, 2009
    As in the instructions above it states to pull the crown out to the first position for the date adjust. However, am I correct in saying that the date adjust can only be completed by pulling out the crown to the second position and rotate the hands to the desired date? When I pull the crown out to the first position it only allows me to wind the watch it does not advance the date. Anyone with experience with this would be greatly appreciated, thanks
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 04, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814048
Points
13579
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Can not determine if my vintage rolex is manual or battery
well if theres a dial you can turn turn it a bunch of timers if it starts working its a manual if not its battery not hard to figure that one out smh people now adays
How to adjust a men's Rolex Datejust, that is very slow?
Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
9helpful
How do you open the latch on a Rolex datejust watch
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
How do i remove the bezel to my rolex datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
54helpful
2answers
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
2answers
Rolex datejust
What you have is an older model Datejust -- or at least an older model movement. During the 1950s, many Rolex Datejust models had an alternating red/black date wheel. Tudor (Rolex's second brand) also had movements with the same red/black date wheel.
BTW, those watches are becoming more and more collectible. Sounds like you may have a nice classic on your wrist! :-)
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
