I want to disable copy function of our HP Laserjet M 1005 MFP printer to prevent missuse of papers & toner. If any one can eplain the process then i will be greatefull to them.
Thank You.
How can I. Disable scanner function from printer
You should be able to turn off copying on your printer through the menu interface on the printer. Have a look in the manual or just scroll down the menu and disable it or turn off.....cheers.
I will say for me, i would rather uninstall then reinstall with the installation disk where during the installation process you will have options to select the functions you want to install.
SOURCE: Scanner Problem HP 1005
for resolve this error you should only change the flatbed scanner wiht a new one. this error is hardwere issue.
by.
M.R.Atyabi
SOURCE: I have an HP Laserjet M1319f MFP printer, when I
You can set the density lighter or put the printer in economode. You may not like the print quality as it will be extremely light. But the toner will last longer.
Save toner
1. On the File menu in the software program, click Print.
2. Select the driver, and then click Properties or Preferences.
3. On the Paper/Quality tab, click EconoMode.
4. Click OK.
Testimonial: "THANX!! BIG HELP, so simple."
SOURCE: I have an HP Color Laserjet CM1017 MFP Printer.
Use Override Mode.
Go to your Menu > System Setup > Print Quality > Replace Supplies > Override Out
