JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
Posted on Feb 06, 2013
Jvc jd-52z575 blue and yellow shadows
Screen shows blue and yellow separated. Looks like shadows on opposite sides of screen. Replaced lamp and it worked for a day or two and then stopped. Any suggestions?
5 Related Answers
A
Anonymous
  • Posted on May 11, 2008
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
A
Anonymous
SOURCE: JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
easyab
easy alberta
  • 132 Answers
  • Posted on Jul 07, 2008
SOURCE: jvc 65 inch I'art tv
1024x768 Normal 0 When A REAR PROJECTION TV has coloured outlines or a 3D image the Convergence Circuits most likely need attention.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Anonymous
  • Posted on Jan 25, 2009
SOURCE: JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Anonymous
  • 5138 Answers
  • Posted on Jan 25, 2010
SOURCE: I just replace the bulb in my JVC HD-52Z575
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
HOW DO YOU RESET THE LAMP USE TIME ON THE JVC HD 56 G787 REAR PROJECTION
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
I need to replace the bulb and ballast in my jvc HD-52Z575 52 in rear projection hdtv-ready televvision. i need to know the part numbers and need to know where they are! I have no manual and would like to...
The parts diagram for the JVC HD-52Z575 is available here: https://www.searspartsdirect.com/model-number/HD-52Z575/1758/0333200.html . The lamp is part TS-CL110UAA. I don't see a separate ballast. If you look at the parts list for the cabinet, a Service manual is available.
I hope this helps.
2answers
BLINKING LAMP LED AND POWER LIGHTS
I have that same problem...we replaced the lamp and nothing happens we hear the fan go on but it goes of .
JVC HD-52Z575
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
