I've tried every way of charging my iphone and it just wont charge. The battery doesn't show up as charging when i plug it in. I mean there is no signs of charging at all. I tried to turn my phone off numerous times to recharge it and still nothing??? Im fustrated as to why it wont charge.
What shpould i do??
There are some methods you can try to fix it. In general, it can be fixed.
Check your charging cable and USB adapter
Test if there's a problem with the USB cable you're using by connecting the iPhone to your computer or power adapter. Check if there is any signs of damage, like breakage or bent prongs. Don't use damaged accessories. And one of the most common reasons why an iPhone wont charge comes from low-quality 3rdparty non-Apple charger cables.
Remove any debris from the charging port
This isn't a very common problem, but it's possible that debris from your pockets or purse or dust from surroundings build up over time could be jammed into either the iPhone's charging port (also known as lightning connector) on the bottom of your device or your USB cable. If there are debris blocks the electricity to reaching the iPhone battery, a normal toothpick, SIM card tool, a bobby pin, or a small needle or a can of compressed air would be ideal tools to clean it. To be safe, back up your data to your computer or the cloud ahead. Power it off before cleaning. You will be amazed how much can get clogged in the port. Connect the charger and see if it works. Still having problems? You probably needs Genius Bar service.
However, if these methods won't work, try more ways in this guide. How to Fix "My iPhone Won't Charge" Issue
Please try the charger with any other iPhone. If it works fine with any other iPhone than your this iPhone has charging port issue in hardware
Beside the cable and the power source, there are two ways to get at this problem:
1) The phone's power port (socket) can get filled with lint or other stuff. Clean it out with a wooden toothpick and compressed air.
2) The cable plug that goes into the phone can be dirty or corroded. Gently clean the contacts with a pencil eraser and remove any remaining debris. At the same time, inspect the tip and the shoulders of the cable plug for any unwanted buildup - remove if found.
Please use a functional charger...
I've tried charging it from a power socket and off my PC. still nothing....help me!! I really need my phone and it's slowly dying...
Are u trying to charge off a PC port or directly from power socket?
