Dryers Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Location of the thermal fuse on the kenmore gas dryer 80
I,m looking for the location of the thermal fuse on the kenmore 80 gas dryer
  • 1 more comment
  • booksatourpl May 11, 2010
    how do you test the thermal fuse?
  • onthethejob1
    onthethejob1 May 11, 2010
    i need a model number,,but its in 1 of 2 places ,,,take the back off,,,1...or remove the bottom panel 2...there white plastic about an inch...onthejob
  • Anonymous Mar 12, 2014
    my kenmore dryer 11062942100 thermal cutoff fuse
Dan Webster
Level 3:
  • Dryers Master 8,221 Answers
  • Posted on Feb 04, 2009
Dan Webster
Dryers Master
Level 3:
Answers
8221
Questions
5
Helped
2379048
Points
25840
It is mounted on the rear of the dryer on the blower housing. location of the thermal fuse on the kenmore gas dr - f8cdc70.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3079
Points
Kenmore 90 series electric dryer. placed load of clothes in, turned on working fine, then stopped. Clothes were warm, tried to restart wouldnt come on. Is it the thermal fuse, and were is it located.
1helpful
3answers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
1helpful
Hello, I think the fuse has blown in my series 80, Kenmore electric dryer. Can you please tell me what it looks like and the location of it. Thank you.
It's a thermal fuse and it is white plastic about an inch and a half long. has 2 wires going to it,usually lt.blue, If you remove the back panel of the dryer it is located near the dryer exhaust above the high limit thermostat.
If the thermal fuse is blown the dryer will not run.
Hope this helps.
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
5helpful
2answers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 • Dryers
1helpful
Kenmore series 80 gas dryer tumbles no heat
Yes. If the thermal fuse has no continuity, then the fuse is bad. Replacing it should get you back in action, barring any other defective items like the heating element, etc. Best wishes.
1helpful
2answers
80 series kenmore dryer not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
8helpful
Gas dryer will not heat up kenmore 80 series heavy duty 72822
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
27helpful
Kenmore 80 series gas dryer w/ no heat
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
5helpful
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 • Dryers
2answers
Thermal fuse
the thermal fuse is located on the heater box,the main fuse is located on the blower box,let me know-mike
Top Dryers Experts
john h
