Question about Samsung RV511A01 Notebook
My laptop Touch is insensitive it delay to click on or may delay to recognition
  • karmatiaziz
    karmatiaziz Feb 05, 2013
    thank u  a lot for helping me
    Sergeant:
  • Samsung Expert
  • 406 Answers
This may be due to software , Or you might have over loaded or system is having virus in startup.
Also check it during power connected mode.
Check the hard drive activity if it is continuously running this may require to empty some HDD space.
Posted on Mar 09, 2013
SOURCE:
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
Delay with touch pad
reinstall touchpad driver otherwise there is an hardware fault.
Feb 07, 2013 | HEWLETT-PACKARD Computers & Internet
My webcam night mode is turn off how can i turn it back on
Face Recognition Usually you'll find the webcam at the top and middle of the laptop screen. One unique feature included with the webcam on newer Toshiba laptops including the Satellite Pro, Portege and Qosmio models is facial recognition. Instead of having to type in a password when you open the laptop, you can set up the computer to recognize your face and automatically load your settings. b> Setup b> To access the face recognition feature on a Toshiba laptop, open the laptop to the registration screen and click the Face Recognition icon. Look at the circle that appears on the screen and align your face so that it fits within the circle, and then click "Next." At the next page, enter your name and password and click "OK." The next time you use the computer, click on your Face Recognition icon from the main screen and look at the webcam so it can recognize your face and load your settings. b> Night Mode b> If you're in a low-light situation you can take advantage of the webcam's Night Mode effect. To turn it on, open the Camera Assistant by clicking the Start button, and then select "All Programs."
Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Once it's open, hover your mouse over the far left hand side of your laptop screen. This will cause a number of webcam icons to appear. Click the "Properties" icon, which looks like a box with a pen over the top left of the box. Click the "Night Mode" check box from the Properties window and then click "OK." b> Other Profiles b> You can also alter other effects and features of the webcam from the Camera Assistant. First open the Camera Assistant by clicking the Start button, and then select "All Programs." Select the "Camera Assistant" folder and then select the "Camera Assistant" software. Then hover your cursor on the far left of the screen until you see the webcam menu appear, and select the "Properties" icon. Then click on an individual "Profile" tab to adjust the white balance, lower or raise the brightness, or correct the colors. As you click on the adjustment, you should see the change reflected in the way the webcam is displaying on your laptop. When you've selected the settings you want, click "OK" from the Profile window.
Feb 01, 2013 | Toshiba Satellite Computers & Internet
USB port not reconizing
The time delay depends on the following factors:
  • Host controller hardware
  • Attached hubs
  • Attached devices
  • USB driver versions
  • Support for USB 2.0
  • Additional system hardware or configurations that may change the timing
Method 1: Initiate recognition of the USB device by using Device ManagerTo initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
Method 2: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus (http://support.microsoft.com/contactus)
Dec 22, 2010 | FireLite (USBFLB80) Hard Drive
My pc's touch pad is insensitive
hmmmm......... a conceited touch pad?
Did u try to check ur control panel and click that mouse/touch pad?
Set that conceited touch pad in that file!
Hope that'll notice u somehow!
Dec 04, 2010 | Sony VGN-Z540NBB PC Notebook
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
How will i know if the mic is working if the laptop is built with mic?
If the mic is present, you can access speech recognition software to check if the MIC is working, to do so: Click Start> Control Panel> Ease Of Access> Speech Recognition Options
Jun 30, 2010 | Acer eMachines 520-2890 Notebook
CLICK TOUCH HAS BECOME INSENSITIVE.  SOMETIMES  THERE IS NO REACTION AT ALL
Reinstall/Update the drivers for touchpad will solve your problem.
Dec 04, 2009 | Computers & Internet
Cq50 laptop touchpad random issue
Remove the battery and the power chord and press the power button for about 30 seconds. Then place the power chord and battery and turn on the system.
Sep 04, 2009 | Compaq Computers & Internet
Samsung RV511A01 Notebook Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
