Question about Roland VersaCAMM VP-540i
How do you lock versa cam printer heads - Roland VersaCAMM VP-540i
Tata indica Timing marks
On. An Indica petroll or diesel there aren't aany timing marks as to say, firstly remove cylinder head, then attach a power bar or ratchet with socket to to bolt on crank shaft pulley. Rotate the engine anti-clockwise until piston one is at TDC (highest point it can go). Then at Te front of engine halfway down the block where engine meets bell housing there is a hole to. Insert a 8mm long bolt, this will lock the crankshaft. On the head on the cam shaft end cap is a hole, insert a screwdriver to fit and rotate cam with. A ratchet until the screwdriver slots in place and the cam cannot move. Replace the head, torque the bolts, fit the timing belt and tension it. Once this is done remove the locking bolt and screwdriver, Replace the cam-tappet. Cover and start the engine
Apr 04, 2014 | 2006 Tata Indica LSi
How to replace front cam shaft seal in Geo Tracker,1.6 liter engine
remove tbelt (lots of steps see link)
remove front cog on cable( 8v head is diffr that 16v to lock it)
tell if 8v or 16v engine
then remove backing plate.
then the seal clamp.
the seals falls off.
reverse above
http://www.fixkick.com/t-belt/tbelt-index.html
there are links to the real FSM pages to, this page covers
every type of cam cog /belt failure there is.
or at head pulls seen here with skips
http://www.fixkick.com/engine/head-pull/head-pull.html
or hear start at step 8 to 12
then do step 14
then jump to 32. and stop
the cam cog bolt is RHT that is CCW takes it off
then remove the backpan , 10mmbolts and last the
seal clamp.
in short, all belts off, fan blade off.
timing cover (tbelt) off
timing belt idler stud and idler center bolt loose.
timing belt off
top cog bolt off (use locking method) ask)
backpan off
seal clamp off.
see how to time a cam , in link 1 above.
Jan 07, 2013 | 1994 Geo Tracker
How to replace a broken timing belt for a 1998 daewoo lanos?? Would there be any head damage?
yes it is quite possible that valves are bent if the cam belt broke or teeth stripped off of old belt, which unfortuneately means removing the cylinder head and getting it repaired (valves replaced and possibly guides) see some of my other posts for cam belt timming marks locations etc...
depending what motor is in your vehicle twin cam or single?
stevenhurc_14.jpg and if its twin cam you usually need cam locking tool for cam gears.
Apr 20, 2011 | Daewoo Lanos Cars & Trucks
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
I nead torque wrench setting for head bolts and cam bolts
Head bolts- 62 lb-ft cam pulley lock bolt- 42 lb-ft cam cap bolt- 16 lb-ft
Feb 02, 2009 | 1999 Kia Sportage
Web cam on laptop wont work
ftp://ftp2.nec-computers.com/ms1719_webcam/ms1719_webcam.zip the driver is here
Dec 25, 2008 | NEC Versa VX Notebook
2000 ford focus twin cam timing
please helpme i need timing marks for ford focus 2000 16 valvs
Sep 11, 2008 | 2000 Ford Focus
Timing zx2 escort TDC ?
The cams have a notch in the back of them (facing driver's side) in which fits a flat piece of steel to lock the cams in place. The notches are not exactly centered on the camshaft, meaning that it's impossible to set them 180 degrees out, because then the flat piece of steel that is supposed to be inserted to lock the cams in place simply won't fit because the top of the cylinder head will get in the way. I highly recommend getting a Hayne's or Chiltons manual if you don't already have one. It should explain this process under the Timing Belt Replacement instructions. The cam lock tool (that flat piece of steel) can be purchased at ZXturner.com:
http://zxtuner.com/product.sc?categoryId=23&productId=191
Jun 24, 2008 | 1999 Ford Escort
Roland VersaCAMM VP-540i Logo
191 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
