Lost safety key
SOURCE: I have a nordic track a2350 and the belt stopped
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
SOURCE: Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
