Integra Dtr-7.8 Receiver Logo
No audio from integra receiver
Audio just stopped. Everything was working fine and then just stopped. Audessy will not work as well
1 Related Answer
Anonymous
  • Posted on Jan 18, 2009
SOURCE: no sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
No sound
Sounds like an input button has been changed. Check that out first
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
2answers
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Doing a job for a friend. Reconnecting all his gear to an Integra DTR-7.1. Everything works except for the surround. I can't get the rears to speak from the receiver. I have verified they work (wires...
if you have everything connected properly, then it wont necessarily utilize ALL of the speakers, unless you have a true 7.1 signal coming in. is it using optical or coaxial? make sure that the options on the receiver are set right......the rears on 5.1 and 7.1 dont work unless they are told to by the receiver....and the signal coming in from the external source ( dvd player, ps2, ps3, xbox....) tell the receiver what it is going to need, in order to utilize the full signal. everything is labeled, and it sounds like you know what you're doing, when it comes to hooking this up, which is always good. it sounds to me, like something isnt configured properly, so i would start there. it may take a while, but you get the idea.....
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
No sound from speakers from components with Integra 6.9 receiver
Thanks anyway.
DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
Top Integra Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
