I try every where to find jabra 8010 bt control center jabra don't have it anymore please advise
SOURCE: Pairing Jabra bt8010 with a Vista Computer?
What you can do is go to dell's website and dl the bluetooth driver
I read it online
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central
Just go ahead and dl the bluetooth driver at the "network" tabs.
SOURCE: Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
SOURCE: Jabra BT8010 doesn't power up
i have a jabra bt8010 but it does not turn on when i charge it it says charging
SOURCE: I have a jabra BT
Long press on the headset button for 15 sec long and you will be able to pair it again with any other device
