Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
SOURCE: donde puedo conseguir el manual
Try www.eaton.com/powerquality. Choose Mexico as your country and then 9130 rackmount as your prouduct. Documentacion tab.
