12Vdc connections for the cpu fan and chassis fan are only 4vdc. Fans run slow and sometimes shutdown with message of cpu fan failure. The main power connector for the motherboard shows 12Vdc.
SOURCE: Possible short on motherboard
It may just be the power supply. That can sometimes be tested by a good computer store. Other wise the only good test is with a new power supply. That's cheaper than replacing the main board and figuring out its the power supply. And yes, the power supply can easily be replaced.
SOURCE: cpu fan not working on asus mobo
remove te wire conected to mb and chech weather if ter is loose connection
SOURCE: Does a M2N68-AM Plus (Asus motherboard) have to
Yes, it will work, just that the fan control will be missing and the fan will run at full speed constantly.
SOURCE: WHEN I POWER UP ON
HI
it is a SMPS problem. SMPS is the main power supply it is also known as smart module power supply..
if you want to check try this link
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
