Hi, By any chance you still have that DSTCD.iso image still? ty
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd Dell
The official method is to contact Dell Technical Support. Dell
Technical Support will request the Service Tag and Express Service Code
from the bottom of the Latitude. If the current user is not the original
Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it
difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS
settings along with the BIOS password. The location of this jumper
varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual
then look for the jumpers near the CMOS battery. Most of the
manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and
the jumper will be joining the center pin to either left or right pin.
What you need to do, is remove the jumper and join the center pin to the
opposite pin. e.g. if the jumper joins center pin to left pin, then
remove it and join center pin to right pin. Now wait for a few seconds
and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
SOURCE: Dude, Can you send me a
DSTCD.iso: click here
just burn the ISO and make it bootable to use it.
Usage:
ASSET new_asset_tag Specify new asset tag
ASSET /d Delete asset tag
ASSET /o new_owner_tag Specify new owner tag (if applicable)
ASSET /o /d Delete owner tag (if applicable)
