SOURCE: How do you change from low speed to high speed?
hi
there is a swich in the back of the car (L/low and H/high)
try it on high .
i hope this will work
SOURCE: Peg Perego Gator Ride On Toy
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
SOURCE: need to replace wheels on sons power wheels
I just replaced the wheels on the red Fisher Price Kawasaki Brute Force. First use a screw driver to pop off the grey middle nut cover. Then pull of the locking nut with black cap that is under the grey cover you just removed.
Once that is removed the wheel comes right off. There are 4 phillips screws holding the hubs together. Unscrew those and the hubs separate into to pieces (one on each side of the wheel).
Simply place the hubs into the replacement wheels and screw back together. Slide the new wheel on (make sure the washer is still on the rear side of axel).
My replacement wheels actually came with the black replacement locking nuts taped to them. Hammer the replacement locking back on the alex, pop the grey hub cover back on and you are done.
If you are missing the locking nuts, take one of the originals you removed with you to the hardware store and you should have no problem getting them. - MTRAGE
SOURCE: will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
