Akai Ewi4000s Electronic Wind Instrument Logo
Bryan Wood Posted on Feb 04, 2013
Ewi and vocoder setup
I am trying to get my ewi to work with my vocoder pedal. I was told that the ewi has to be set to self oscillate. When I try to adjust the breath sensor to self oscillate I get a constant humming tone. Can anyone help me with these adjustments ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
914
Points
Hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
  • Anonymous Jul 28, 2013
    hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
    thank you!
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Reset. EWI4000s
Try this out
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
How could I set up quarter tone in a precise way, that I could control with bend control of EWI?
Here is a good forum to join:http://www.patchmanmusic.com/forum/ Depending on what you are using for a sound module, I would recommend setting the pitch bend limit or range on the sound module to what you want and controlling that setting with whatever setting you have on the EWI. Read your manuals carefully and you should be able to do it.
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
1helpful
Internal and external sounds at the same time
Without reading the manual, the easiest solution that occurs to me is to not use a cable between the audio out on the Ewi and the amp or mixer you are using. You can also set the main volume to zero. That setting does not affect the program volume.
2helpful
3answers
My akai ewi 4000s kind of froze
Please try to reset the ewi. You can do this like this: Shut down ewi. Press down the four little white buttons Level, FX, Setup and Trans. Keep them pressed while starting up the ewi.
This is a factory reset.
I hope this works for you.
2helpful
EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Kind regards,
Fred Roubos.
EWI won't respond to comands
I've got the solution.
Turn the EWI off.
Press the LEVEL, FX, SETUP and TRANS buttons all together.
Turn on the EWI.
This is a Reset to Factory Preset.
Greetings Fred Roubos.
IMac not detecting EWI4000s via midi-usb adapter
My Imac does not find the midi ports form my Ewi 4000S. When I try to install midi ports ( just one choice possible) it does not work. What can I do ?
Top Akai Music Experts
ilias
ilias
Phelix Oguta
Phelix Oguta
Are you an Akai Music Expert? Answer questions, earn points and help others
