I need more info, I'm not sure what the fuse controls? Where is the fuse located and what is the amp rating?
Could be a faulty component or wiring circuit? Does it blow as soon as you plug it in or after you turn on the key? Does it blow quickly?
if you know witch fuse is blowing that means you have a short so if you have an idea how to trace it do so but make sure you have the right fuse with the correct amps then check to see if the wire have a bruise or if something is pinching or mashing the hot wire
Because your radio is shorting out or you have a pinched wire somewhere in wire harness. Fastest way to find out is remove radio and disconnect all wires, then plug another fuse in. If it blows than its a wire problem, if it doesn't radio is bad.
There is a short somewhere in the tv. The blowing fuse is trying to keep you from getting electrocuted. Take the tv back to where you got it from. Bad power board.
If you can pull the plug from the wiper motor and try fuse. If no change disconnect the plug to the electric windows and try fuse. Unlikly to be in dome light circut unless you have had aftermarket sterio system or other accessory fitted recently
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
What is rating of fuse in your TV like amperes and volts. There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two. You can increase little bit current rating of fuse to avoid blow off.
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse.
Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
