Stoves Premier 600GRa Gas Single Oven Logo
Dave Hunter Posted on Feb 04, 2013
Stoves Q601G No gas comming through
After a fuse blown replaced the 3amp fuse everything ok except for cannot light Oven as no gas comming through!!
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 • Ovens
2answers
Where is the fuse location for Kelvinator wall oven model # R30-1
Kelvinator Oven Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/electrolux-kelvinator/oven/
How to light an oven of kelvinator KCL86GSC gas co. Kelvinator ... Replacing thefuses on my kelvinator stove model H
Nov 15, 2015 • Ovens
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 • Ovens
What is the single fuse in top panel of electric oven/range for?
Hello there and welcome to fixya
Normally the single fuse that you have found is for the electronics like the clock and the various other basic funtions o the stove ect ect if this fuse has blown out it will limit the stove or the cook top to be able to do such things like setting the timer or turning on the ovens light and it may also effect the troubleshooting program that is built into the stove ok like error codes and simple things like this
Hope this is very helpful for you '
Best regards Mike
1helpful
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 25, 2011 • GE Ovens
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
1helpful
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
2answers
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
