Health & Beauty Logo
BTFritsch Posted on Feb 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My batteries in my jazzy select gt power chair are dead can I buy used ones?
My chair for over sat for over 6 Months because I had a triple by-pass, can I buy used ones to have someone install.
Tigre Noir
Level 2:
Sergeant:
  • Expert 317 Answers
  • Posted on Jun 30, 2013
Tigre Noir
Expert
Level 2:
Sergeant:
Answers
317
Questions
0
Helped
143066
Points
700
Not a good idea to buy USED power chair batteries. Even new ones just have a 3-4 year life span. But yes, you can buy used batteries.
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Sep 07, 2009
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
oregoon
  • 175 Answers
  • Posted on Oct 03, 2009
SOURCE: What kind of Jazzy select 6 power chair does my
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Anonymous
  • 103 Answers
  • Posted on Nov 16, 2009
SOURCE: Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Anonymous
  • 61 Answers
  • Posted on Mar 24, 2010
SOURCE: Hello,
It sounds like a battery problem more than anything. If it were a fuse, the chair would not move at all. When batteries are stored, they need to be kept charged by charging every couple of week or so (ideally). There may be other problems causing this, such as a short somewhere or a problem with one of the motors/brakes/electronic componets draining the batteries, but I feel this is unlikely given what you have described. I would have the batteries checked at a dealer with a proper battery tester. Preferably have the charger checked at the same time. We use a specific battery/charger tester in our shop that is connected to a computer and will give a graph of the battery/charger condition. This way there is no arguments as to whether the batteries or charger is faulty. Hope this has helped.
Anonymous
  • Posted on Jul 30, 2010
SOURCE: Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
What does a flashing speed light on jazzy select 6 mean?
INFINFB2047 Jazzy Select Troubleshooting - Pride Mobility
https://www.pridemobility.com > pdf > infinfb204...
PDF troubleshooting instructions for the Jazzy Select Power Chair. ... 1 Flash. The batteries need charging. Check the battery connections. If the battery.
3 pages
Videos
https://www.google.com/search?q=flashing+speed+light+on+jazzy+select+6
1helpful
Can I use the serial number to find out what Model Jazzy Power Chair I have
Hi batteries for jazzy GT. ::: UPG UB12350 12V-35AH internal thread. E/Bay sell a 2 pack US $119…99 Cheers
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
My batteries in my jazzy select gt power chair are dead.would it be possible to replace them with a car battery.
I would not recommend you to do this. The batteries that are used for this application are a deep cycle battery. A regular battery may get hot and you will just have problems. Get the correct batteries for the unit. They take U1 32Ah 12V batteries.
Jazzy Select 6, Charge batteries. Green light comes on...run for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
My Jazzy 6 Scooter will not charge at all, no matter how long I have it plugged in, I have had it since May of 2010,, used it all of 2 months and it has been in my garage since.
bzred since it sat so long without charging the batteries are shot and need to be replaced. If you had the problem before you put it up then you can have a bad charger or even bad batteries, I would replace the batteries and check the charger. Fortunately the chair has a 12 month warranty on most parts except the batteries. Better yet contact the provider who sold you your chair and they will have to repair it under warranty. If Medicare paid for the chair then they will pay to replace the batteries Hope this helps you
2answers
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Jazzy 1113. The chair was doing great. The user passed away,
Naw the batteries are shot Get yourself two U1 batteries from a battery warehouse or store that sells batteries around $200.00 for two
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
