Question about Leapster Learning System
Leapster wont power on?
Leapster wont power on... it has new batteries but the connections look like they have a little corrosion on them but it won't turn on at all. any suggestions?
    Sergeant:
    Habit-Forming:
  • 158 Answers
Take a fine file or sand paper to the connections this usually works.
Posted on Feb 04, 2013
3 Suggested Answers
SOURCE:
  • 110 Answers
SOURCE: When we inserted a new game cartridge (Pet Pals
its not recognizing the game, contact is probably dirty. take an eraser and rub the contacts of the cartridge and get them super clean, blow out ALL the debris and that should fix it.
good luck!
Posted on Jan 29, 2011
SOURCE: Leapster pen not working
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on May 15, 2009
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Aug 10, 2011 | LeapFrog Leapster Explorer Learning Game...
Leapster wont switch on
if the light goes green for a very short period before going red again it means theres a short on the circuit board. u can try and find the problem but because the circuitry is very small, it wont be easy to find. only other solution is to buy a new circuit board :(
Dec 25, 2007 | Sony PlayStation 2 Slimline Console
New batteries installed and leapster learned will not turn on. Is there any way to reset it? I even tried new/different batteries that are brand new. We have an 11 hour trip tomorrow!!! Ahhh...
With new batteries the leapster should of turned on. Take the batteries out and look on the contacts inside where the batteries would normally go. See if there any corrosion or anything sticking to the contacts. If it is then clean it with a rag and glass cleaner and then try new batteries again, if it doesn't work then you know the mainboard inside is bad. Also if nothing is on the contacts and you know for sure the batteries are new then the mainboard would still be the culprit. At that point you would have to buy a new leapster because there is no parts available for it. If its under warranty bring it back to the store where you got it so they can get you another one.
May 28, 2011 | Video Game Consoles & Games
Leapster 2 powers up to warning screen and then powers off. Batteries are new and all contacts appear to be clean.
Connect it via USB to your PC/laptop. It'll connect to the Leapster website and appear to update firmware. Once it is finished, it will let you know to disconnect. After that it should work. I had the same problem and did this, and now it's working fine.
Jan 02, 2010 | LeapFrog Leapster 2 Learning System
Leapster wont turn after changing batteries
if there is corrosion from old batteries, you will need to neutralize the acid. take an old toothbrush and some baking soda with a little bit of water and brush the coil and convex area of the copper connector.
Leapster will also offer you a new one at 1/2 the price if you agree to ship back your old broken one.
You will need to get their phone number off the net.
Oct 22, 2009 | Toys
Power goes out (new batteries) or starts making funny noises, screen goes crazy and turns off. Leapster 2
The item may be faulty if it is new. Otherwise some batteries are not a good enough quality to run certain electronics.
Oct 21, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 unit turns on, warning msg re. seizures and flashing lights stays for a few seconds then shuts off. Has new batteries. my daughter has the same problem with hers it turns on and brings up an...
We have 3 Leapsters. The old green model and 2 newer models. Our green one started doing that not long after having it. But it still works and if it shuts off, then we just turn it back on again. When I called up c/s for Leapster, they sort of make it difficult to return. And then I was not promised a new one, but it could be new or refurbished. I let it go. Now w/ the 2 new models, I believe this has happened. I've questioned if my kid's are accidentally hitting the power button. I have seen the green one power off before. I purchased the $10 plug in's. So worth it. No more batteries. And we haven't had any issues. So perhaps it is the batteries. Call up Leapster though and see what they have to say. Good luck! :)
May 26, 2009 | LeapFrog Leapster 2 Learning System
Leapster not powering on
I have never used the Leapster before, But I researched it a bit and discovered that it uses "AA" Batteries. Were the rechargeable batteries you used before designed for the Leapster or were they older Ni-Cad (Nickel Cadmium) style batteries? Older Ni-Cads put out a slightly higher voltage than standard (1.7v) as opposed to the standard 1.5v. This could possibly cause problems. If you have only had it for a few months than it should be warranty protected. Hope this helps. Cheers!
Aug 31, 2008 | Video Game Consoles & Games
Hold down the powerbutton for 3-5 seconds then release.
Sep 28, 2007 | Nintendo Game Boy Advance Console
Leapster Learning System Logo
222 people viewed this question
Top Leapster Toys Experts
James Hensley
James Hensley
Dennis Crouse
JessicaChane2345
Are you a Leapster Toy Expert? Answer questions, earn points and help others
