In the last few weeks the alarm has been going as the temperature keeps fluctuating between 10 and 12 degrees. I had switched it off when I emptied the contents and there is hardly any food in there. It doesn't seem to go beyond 13 degrees ????
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
SOURCE: We have a bosch economic no frost freezer which is
The starter/overload relay may be bad or the compressor is overloading the relay. See how to test them here. How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Hi monilvsjay - Typically when the freezer is beeping it indicates a warning of a possible malfunction or an unsafe temperature inside. The silence the buzzer, press the ALARM OFF button, however if you have already done so try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. The freezer could possibly be experiencing a communication problem with the temperature control/board or wiring failure.
