Hi here are the codes at this link below...
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.htmlspecifically the code is explained below....
USER INTERFACE HEARTBEAT FAILUREIf a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
1. Check for continuity of the User Interface harness.2. Check wire harness connections to the User Interface and the Central Control Unit.3. Replace User Interface if drum is rotating.4. Replace Central Control Unit if drum is not moving.
If you wish to DIY then you MUST obtain a service manual for you exact make and model...
However if you don't wish to DIY, then the very best thing to do is contact a local or head office from Whirlpool, and ask for a referral to an authorised service center. Make contact there, and ask for a service call, now if worried about costings, then when in face to face contact, simply ONLY first ask for a "Quote" then go from there once appraised of the potential costings, at the least then you can decide as to repair or replace?
"Local interface problem detected." is the message on startup of the Xerox 5638 WorkCentre copier. No further functionality. Any clues to a fix?
