Coffee is not coming out hot any more.
SOURCE: My cuisinart carafeless coffee maker is not working..
dear,
read this comment and you will get what u want .
or if any confusion, read its manual keenly.
regards,
SOURCE: Where do I purchase replacement charcoal water filters for my coffee maker?
I found replacements at Bed Bath & Beyond
SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
SOURCE: Cuisinart DCC-1150 series coffee pot how to clean reservoir
Hello dhubert14,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. This an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it, but most
people don't know about this fix. I hope this is really helpful to you, dhubert14. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: the heater plate on cuisinart cbc-1600 coffee
The CBC-1600 comes with a thermal carafe. therefore, it doesn't rely on a heater plate to keep the coffee warm.
