Denon AVR-1708 Receiver Logo
Posted on Feb 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can n ot get rear surrround speakers to work
This is properly wired in the rear but we can not get rear surround speakers to come on.also how do I get to 7.5 surround?
Mike Neath
Level 3:
  • Master 315 Answers
  • Posted on Jul 08, 2009
Mike Neath
Master
Level 3:
Answers
315
Questions
0
Helped
193734
Points
1246
Hiya,
Make sure back speaker's power amplifier is set to the correct channel
Check the surround back speaker setting is set to something other than "NONE"
Check that the surround sound playback mode is set to either 6.1 or 7.1
Hope that helps
Mike
Anonymous
Level 2:
  • Expert 119 Answers
  • Posted on Feb 25, 2009
Anonymous
Expert
Level 2:
Answers
119
Questions
0
Helped
61315
Points
167
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
I CANNOT GET THE WIRELESS REAR SPEAKERS TO WORK. ALL I GET IS A VERY FAINT STATIC.
I just fixed this problem with my theatre system. First, if you use speaker wire and not plugs, pull out, than reinsert the wiring, sometime it doesn't properly connect. Make sure that your sound field is turned to Surround Sound. Funnily enough, these are the two most common issues.
Then check rear speaker volume. If there is a switch or button to choose A, B or A+B speakers, attempt adjusting this.
That should do it. Even if you're not playing surround enabled content, but to be safe, ensure you are.
3helpful
2answers
The rear and centre speakers are not working but the front and subwoofer speakers are working. What do I need to do to get the three working. In the booklet it says the rear speakers might not work becasue...
From them manual Troubleshooting section:
"When listening to a CD or radio, sound is output to the front
speakers (L/R) only. Select "PRO LOGIC II" by pressing
PL II (Dolby Pro Logic II) on the remote control to use all
six speakers.
• Make sure that the DVD disc is 5.1-CH compatible.
• If you set C, SL, and SR to NONE in the speaker mode in the
audio setup of the setup screen, no sound is heard from the
center speaker and the rear left and right speakers. Set C,
SL, and SR to SMALL."
This means you might want to check your speaker settings again and make sure the Cenyer and Surrounds are defined.
4helpful
How do i put the surrround sound on my tv?
Depends on the complexity of your home theater system, but if you are just wanting to get sound from your tv to a generic souround sound, this is very simple. On the back of your tv, there is a audio output with 2 rca connectors. One is white and one is red. Also on the back of the sound system is the same colored inputs. Get the needed cable to connect the 2. You should have surround sound. Given you tv doesnt have audio outputs, your media player ( dvd, vcr, blue ray, sattelite) should have an audio output. Connect the electronic the same way as stated above.
1helpful
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
3helpful
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
LG 42Inch lcd tv and LG ht963pa surround home theater
most programs don't have the 5.1 so you won't hear it
I have a set of RM300 Polk sub-sattelite speakers. Have had them for some time and still love em but.... The foam surrrounds on the bigger sattelites have disintegrated. Polk says too old cant fix. ...
Yes they can be re-surrounded. It is not that hard, it just taes some practice. How big are the speakers? Look for a local speaker repair shop. They are few, but still exist. The hardest part is finding the correct surround. As long as the remainder of the speaker is in good shape, you will find these to be good as new once done. FIrgure about 2-3 days to complete the job properly.
Dan
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
