When i push power button it doesnt want to boot, i need a diagram on inserting the wiring to the motherboard
SOURCE: MSI MS-6154VA wiring diagram
Mobo Manual here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=338
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
SOURCE: wires connection
If you know where the board came from i.e. a dell laptop model number or dell desktop model number this would help.
The issue is this is a
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
propretary version of the motherboard and can have different configurations based on what machine you got it from.
This is a link to the Dell Dimesion 8400 spec for that board.
The E210882 is commonly the D865GLC motherboard from intel spec is here.
SOURCE: power sw, reset sw, HDD led motherboard connectors
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
97
SOURCE: number codes for giving connections to HDD led,Power led, Reset SW & Power SW to motherboard
Those are really tricky and always vary from motherboard to motherboard.
without the exact model no one will be able to tell you exactly. But I'd recommend that you start out with the power (pw) plug and try trial and error. The only ones really necessary are the pw and reset. the only 2 that are polarity sensitive are the HDD light and pw led.
