The acceleration button is extremely fickle. Sometimes it works, usually it doesn't respond to SPEED INCREASES. However, the button to SLOW DOWN works well. Also, the INCLINE BUTTON is also fickle. Sometimes it works, other times, no. The DELCINE BUTTON, however, works well. Thank you for taking the time to help me out. Mark
Are 2 solution, try to replace the acceleration button, or membrane for to fix it. 2) replace the complete Console.
You can call to the service support and ask for the membrane for to replace, or see if your operator manual for the part number.
Blessing
[email protected]
whatsApp:+50588611441
SOURCE: the speed arrow. when I
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1
Stand on the side rails of the treadmill for safety purposes. Remove the safety key.
Step 2 Press and hold the two
incline buttons. The incline buttons are blue and on the left side of
the display. Hold the up and down button simultaneously. Release the
buttons when the display reads "Calibration."
Step 3 Press the green start
button located either above or below the large, red stop button
(depending on your model). Stay on the side rails as the treadmill belt
begins to move. Both the speed and incline should go through their full
range from lowest to highest, and then back down again.
Step 4 Repeat the process if the
display does not read "Calibration Successful.
