Wine & Spirits Logo
Anonymous Posted on Feb 03, 2013
Do canned beers taste different from bottled beers?
Openers Plus
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 6 Answers
  • Posted on Nov 05, 2014
Openers Plus
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
6
Questions
Helped
2039
Points
8
Yes, they taste different. Best is draft, this gives you the fresh taste you want. If you can make sure the keg never gets warm. Went to a bar with full kegs sitting at room temp. Run from places like this.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Feb 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
13
Helped
5851
Points
45
Essentially, no. Some people may argue this statement, but basically what they taste is the aluminum. Try pouring the beer into a glass - it will taste the same. Cans are a great way to store beer; however they are not often used due to the cost surrounding their manufacturing process.
I am using yeast balls to brew my beer, that I bought online. How many yeast balls should I use for an average brew of beer?
It's very individual. If you use more, it speeds up the fermentation process but also alters the taste. I would recommend somewhere between 15-30 balls. But you should check what the directions say (yeast balls should come with some instructions on the back). Because if it's a different make to the one I'm used to, it might be completely different quantities.
tip
Homebrewing can take a while to get the hang of, but once you get more...
Homebrewing can take a while to get the hang of, but once you get more experience, you will become addicted to the thrill of brewing the perfect beer. Not only does it work out cheaper than buying your beer in bars it also just tastes so much better.
Here are some basic tips to help you with a successful homebrew.
    1.Read the recipe really carefully and don't be heavy handed especially with the malts as this can ruin the taste.
    2.Keep a log of your brew. Don't be lazy about this, even if you think the recipe is really simple. In the future you can then make small changes to perfect the brew based on your notes.
    3.Keep your equipment really clean. It makes a huge difference to the outcome. Ive even used vodka as a great cleansing agent.
    4.Control fermentation temperatures. Buy a stick on thermometer from a beer brewing shop to keep an eye on the temperature.
    5.Boil your wort for 60-90 minutes as this will greatly improve the beer.
    Most importantly relax and enjoy your efforts.
on Dec 09, 2013 • Crafts & Hobbies
We are making our own wheat beer and followed all the instructions really carefully but there is a horrible egg-like smell coming from the barrel. Is there something wrong with it?
A good wort should take like a warm, flat beer. It doesn't sound like anything is wrong with your beer but you won't know for sure until you taste it. If it tastes bad it might be a sign of infection.
Can I use distilled water to brew beer? I dont like drinking the water where I live so I usually use distilled water but was not sure if it would work with beer.
I wouldn't brew beer with distilled water. It doesn't contain all the minerals you need for a good taste in beer. You could always use bottled water.
Is it necessary to keep cleaning and sanitizing the equipment when you homebrew beer?
Yes! If you want your beer to taste good and not have 'beer swill' which tastes horrible - you should clean and sanitize your equipment really carefully after each brewing session.
What kind of beer is best paired to drink with a chocolate dessert?
Pairing beer and chocolate can be a very fun and tasty treat. Depending on the type of chocolate, there are several beers that could compliment the taste. Below is a site I found that goes through various chocolates and their best beer pairings.
http://billybrew.com/beer-and-chocolate-pairings
What is the shelf-life of beer?
Beer does not spoil in the same ways as other drinks. When a beer spoils, the taste characteristics change, not so much the texture. Most beers retain their quality for about 6 months. If stored properly, it should still taste good for an additional 4-6 months.
2answers
What are trappist beers?
In order to be considered a trappist beer they must fulfill two requirements - the beer must be brewed onsite at a trappist abbey and they must be brewed for non-profit purposes. There are currently 6 remaining brewing abbeys in the world - five in Belgium and one in the Netherlands. The most recognized trappist beer is Chimay.
4helpful
2answers
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Top Wine & Spirits Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
