Olympus Camedia C-5000 Zoom Digital Camera Logo
Posted on Feb 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Olymp c-5000 won't turn on red/ yellow lights blink/ beep 20 time
Fully charged batteries. tried 2 was working all of a sudden stopped. now it beeps and the orange/yellow lights blink and beep exactally 20 times when i try to turn it on.
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 64 Answers
  • Posted on Feb 02, 2009
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
64
Questions
Helped
26447
Points
119
Furrybutts (hehehe, like the name), This could be a lot of things and I'm sure there's a service guide out there that will tell us what 20 beeps and flashing lights mean, as I don't have one, let's figure it out.
Firstly, digi-cams and rechargables, eerrrrrgggg (Mr Burn's shudder) yeah they 'work', but for trouble shooting and iffy times, lets look at some half desent NEW alkaline batteries - for about $3-$4, it's worth it for this troubleshoot.
OK, did they work?, No?, lets look at the memory card. The cards are supporsed to be only put in one way, but ... lets take out the card, clean the contacts with a clean cloth/tissue, and put the card back in being sure it's in the right way. Still no go?
Take the card out again and try and turn the camera on without the card. Any changes?
This camera uses an XD memory card. I can't remember if it has an internal memory - what we're looking for is whether the memory is damaged and the camera is happy using it's internal memory or still erronous with no memory. Do you have access to another XD card to try it (this camera will take a MAXimum of 512mb, so don't try and card bigger).
Lets leave it at this for now and you let me know how things are going?
**.The best way to acknowledge contribution is to rate it's relevance.**
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
www.gewizrepairs.co.uk
1helpful
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 • Vacuums
2answers
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
Phone not turning on keep beeping red light. phone make. sony ericsson w580i
Your battery is probably out of charge.... Try charging it.... If the red light keeps on blinking even after charging it for a sufficiently long time You will either need to
1. Change your Battery.
2. Perhaps change your charger.or get your charging port checked and repaired.
Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Weird problem. Camedia d-520 doesn't turn on. Blinks and Beeps.
I'm having the same problem with mine. Happens on rechargeables or brand new standard batteries as well. Very frustrating. I can't take more than 2 videos in a row without the dreaded orange/green lights flashing (low battery warning). Leaving it for 10-20 minutes and it works again, with the battery charge showing full.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
