Innotab 2s will not turn on. Checked all battery connections removed all batteries and re installed batteries, but still won't turn on. No picture or sound Luana Dagdag on Feb 3, 2013
try another USB cable/usb port. if that doesn't work: For windows--check under device manager>>disk drives>>look for vtech nand1>>right click--uninstall>>unplug the toy>>plug it back in>>turn it on>>try to access Learning Lodge again. For Mac>>open Disk Utility while toy isnot connected to toy.>>plug toy to computer>>turn it on>>look for anything that says vtech.if you do go to Learning Lodge--send error report--call vtech
see this causes and proceed . God bless you If the camera won't turn on, check the batteries, or connect the
camera to an AC adapter. If that doesn't work, remove all batteries,
disconnect the AC adapter, wait a minute, reinsert batteries and
reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
