I cant find the fuse box on a 1991 toyota corolla, or why does the wipers not work
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
SOURCE: where's fuse box & fuse for power windows Toyota Corolla 98 LE?
Fuses can be tricky. Check them all to be sure.
SOURCE: I need a diagram for a 2003 toyota corolla interior fuse box
Have you checked to se if there is freon in the system? If there is no freon, the compressor will NOT run.
SOURCE: location of fuse box for 98 toyota corolla
Also, for radio, cigarette, and others: behind the "storage only" box left of steering wheel. Pull that door open, up and out.
Have you checked the fuses? Also, turn on your wipers and check for power at the wiper motor. Either bad fuse, motor or switch.
