Frigidaire GLTF2940ES Front Load Washer Logo
Posted on Jan 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spin cycle not working
Washer will drain,no matter the setting spin cycle does not kick in , you here the motor it runs for a couple minutes and the machine shuts off,could you list what to troubleshoot in order please,thank you.i apoligize the moodel is a frigidaire gallery front loader model number gltf2940es3 thank you again
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Jan 17, 2018
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206034
Points
1556
You will need to unplug the machine and take off the back panel and look for a small 5mm pipe leading upwards, take it off and blow gently into it you should hear a click and another one when you let the air out again if so then the small pipe where you took it from is blocked preventing the switch to work properly , unblock the pipe with a pipe cleaner or metal rod its normally full of soap goo return the pipe and close the back up and run the machine again eric
5 Related Answers
Anonymous
  • Posted on Sep 24, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Anonymous
  • Posted on Dec 03, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Anonymous
  • 58 Answers
  • Posted on Mar 09, 2010
SOURCE: washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Anonymous
  • Posted on Aug 08, 2011
SOURCE: I have a Frigidaire Gallery front loader. It runs
remove cycle knob
Why won't my 4GLTF2940FS front load washer will not spin. It will go though a wash cycle, but when it is time to drain/spin the load it immediatley goes to No Spin, then shuts down. The water drains
Hello friend, I appreciate your post!
Based off the information you have provided if your Frigidaire washer is draining and rinsing but not spinning it could be an issue with your timer or motor. I would reset your appliance by disconnecting power to it by unplugging it or flipping the household circuit breaker for ten minutes. If that does not work I would recommend having a technician out to the home to properly diagnose and repair the appliance, since it could be any one of these underlying issues. Hope this helps. -Matt
2answers
My washer stopped during the spin cycle. Now I can get it to fill with water But aggitate and spin it just makes a noise and the tumbler is locked up tight
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
2helpful
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
3helpful
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
1helpful
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
2answers
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Washer will only wash.
A Clothes Washer with the complaint of "Fills, Agitates, But Does not Drain or Spin" can be:
Defective Door/Lid Switch (Very Common): The lid-switch "that clicking sound you may hear when opening/shutting the door" can become defective after constant "slamming or dropping" or the door. This switch is a relatively simple repair. The lid switch can be located on the inside top of the machine and can be typically removed by (2) screws and un-plugging the electrical from the inside. The lid-switch costs about $15 or so for the part.
Drive-Belt or Coupling (Common) - You may have either a belt or coupling that may connect to the motor, transmission (pulley) and pump (on direct-drive machines). The belt and coupling is the driving force that engages your tub to spin and drain. Typically, upon receiving power from the lid-switch at beginning of rinse cycle, the "drive-train" (motor, transmission and water-pump) is "kick into action". Belt-Drive Machines: The belt is fairly simple to replace and runs about $20 or so. The belts circles and inter-connects with the Transmission Pulley, Motor Pulley or even with the Water Pump Pulley (Metal Cylinder type with belt groove). Direct-Drive Machines: The coupling runs about $10 or so is a little more complicated to repair. The coupling is a total of (3) small - inter-locking plastic components located and attached between the motor (mounted to shaft) and transmission (mounted to shaft) and enables the transmission to spin, upon motor receiving power.
Timer Control - (Very Uncommon)
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
