Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
SOURCE: touchpad's scroll button not working
Download and install this driver:
http://www.acerpanam.com/synapse/data/7117/documents/Touchpad_Signed_Synaptics_v9_2_3_1_C.zip
SOURCE: Scroll function on my Toshiba Satellite TouchPad isn't working
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
SOURCE: Synaptics Touchpad Enhancements stops working
I had this problem on my Dell Inspiron 1318, so I went on to their support centre and through the Chat to a technical advisor tool, they uninstalled and reinstalled the driver which controls the touchpad and now the problem is completely gone. I suggest you contact Acer or the customer service of the company that you bought your laptop from and ask them to do something similar. I didn't even need to send my laptop back, Dell were able to take control of my laptop remotely and it only took about an hour in total. Hopefully your provider will be able to offer a similar service.
You may even be able to do this yourself if you can figure out which touchpad driver you need and look on the Acer/laptop maker website support and look at updates for drivers or downloads or something similar. Personally I found using the company's expertise much easier.
SOURCE: scroll on touchpad not working
Hi! You may access touchpad settings by accessing control panel then go to hardware and devices then click on mouse. It will show a tab that has a drop down option for left and right click functions. Thanks for visiting FixYa.com!
