Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
At my apartment complex not enough hot water!
There is a leak at my apartment complex coming from the MOEN shower head or faucets. There is cold water returning to the water heater making the units never turn off and people not receiving hot water. If the shower or faucets are not leaking could there be interior leak with a cartridge to send cold water back though the lines. There is no water of any leak on the interior or exterior of the building. I believe over 7000 gallons is getting wasted everyday. Can you help??
  • 3 more comments
  • justaguilar Feb 01, 2009
    I don't have any showers leaking at any of the apartment units. I want to know can the shower cartridge leak cold water back toward the hot side to though off the hotwater heaters. The waterheaters can hit temp when I turn off the lines to the units but when I turn the lines on again after waterheater hits temp the return lines return cold water?
  • justaguilar Feb 02, 2009
    To all 73 apartments? There no easy way to know if the cartridge is good or bad? Normaly the shower leaks and we change the cartridge now there's no leak but cold water going to the hot water lines?
  • justaguilar Feb 03, 2009
    a moen shower cartridge.
  • Cesar Bikic
    Cesar Bikic May 11, 2010
    question is the shower leaking?, do You have a leak or not on the shower? I do not understand
    Please explain witch of the 3 or 4 items are leaking
When I open the shower faucet, there is normal flow of cold water but when turn towards the hot wter, the flow reduces drastically.
Can you give me probable cause?
Thanks
Posted on Feb 03, 2009
    Scholar:
  • 141 Answers
What cartridge? a filter? get back to me
Posted on Feb 02, 2009
  • Cesar Bikic
    Cesar Bikic Feb 03, 2009
    You have to find the leak, never a shower cartridge will leak like that Or either some body is stealing the water or You have a leak some where under ground or every where on minor ways , call me I am in Florida my cell 786 370 1812 Caesar
    Problem Solver:
  • 7 Answers
You need to change the cartridge
SOURCE:
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Put new moen cartridge in and I have no water at all coming out of the faucet
Do you have cold coming out? was this the problem that caused you to change cartridge? Did you use a Moen brand cartridge? if yes then the problem is in the balancing spool which is located on the left side of the valve it is a round brass fitting with a slotted head you can remove spool while water is off and clean debris from spool make sure you hear a clicking noise while shaking the spool if not lightly tap it on a hard surface until you hear a clicking noise or if you used an aftermarket cartridge like Danco brand return it and call moen for a free replacement
Nov 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower head leak
Single handle shower controls always have some water trapped inside. It has probably freeze damaged the cartridge
Apr 29, 2009 | Moen & One Handle Tub & Shower Faucet
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
412 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Thomas F. Schneider
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
