I have bought the phone week back through home shop Micromax x455 mobile , what unable to enter factory code for restore factory setting. Long procedure for saving the mobile numbers. c v reddy [email protected]
SOURCE: I am unable to connect using gprs on my Q3
While using a Q3 as GPRS modem: I ve noticed that the SIM being used to connect to the Internet should be the Primary Sim (i.e. First sim), If you are configuring GPRS for the II sim, it gives authentication error . However, this is not a problem if you are using Internet through Mobile
SOURCE: What is Restore factory resetting
try below reset code
Micromax
Q7 codes
*#8375# - Software Version
*#8929# - Reset
*#1111# -
WiFi
*#87# - Auto Hardware Test
*#1234# - A2DP Normal/PTS mode (no
idea what PTS Mode is)
*#900# - BT Local Test (no idea about use)
*#901#
- BT Local Test 1 (no idea about use)about 3
weeks ago
SOURCE: I have Micromax X235 mobile
Dear Sir,
You can restore the factory settings of the mobile phone. The default
factory setting password is 0000
If you want user guide get it from the below link
http://www.micromaxinfo.com/products/product_downloads/guide/X235_UM.pdf
right click and click on save as to save this pdf file.
Thanks
