Turning Wi-Fi on and connecting to a
Wi-Fi network
1 Touch > Apps tab > Settings >
Wi-Fi from the WIRELESS & NETWORKS
2 Set Wi-Fi to ON to turn it on and start
scanning for available Wi-Fi networks.
Tap Wi-Fi menu again to see a list of
active and in-range Wi-Fi networks.
• Secured networks are indicated by a lock
icon.
4 Touch a network to connect to it.
• If the network is open, you are asked to
confirm that you want to connect to that
network by touching Connect.
• If the network is secured, you are
prompted to enter a password or
other credentials. (Ask your network
administrator for details)
SOURCE: I have no credit on
If its an iPhone, when you have to go to Settings, Wi-Fi, turn it on and then connect to your Wi-Fi.
SOURCE: How do I get my
You don't, unless you pay the extra 30bucks to Sprint to tether. They killed the hotspots with the updates. Or you can root to downggrade back to 2.2.1
SOURCE: I had just bought a
Yes, Verizon will help you with this.
You may need to reset the phone to get in without knowing the pattern lock. To do this (you will lose your saved phone numbers and any stored data!!), follow the steps:
1. Remove battery, then reinstall battery.
2. Hold Volume Up, Home and Power buttons for several seconds, until you see the setup screen.
3. Follow the prompts to set the phone up again.
SOURCE: EVERYTIME I TRY TO CONNECT MY LG OPTIMUS T TO MY
i went into the wifi set up on the optimus s and went to the bottom of the menu that shows what networks are available and clicked on add network. From there I entered the SSID from my router, then put in the password for the router, (password will depend on whether or not you have yours password protected) I hit enter from there and it connected and stayed connected.
