Was just driving down the road and Jeep started to squeal really loud then started making a loud grinding sound. Pulled over and when I tried to take off again it made the loud grinding sound and wouldn't move. Then I put it into reverse and it would move. Then put it in 4lo and it would move forward and same with 4hi. Any suggestions on what could be the cause of this?
SOURCE: 94 jeep cherokee 4.0l automatic 3 speed transmission problem
THIS IS 2 LITTLE PLASTIC TABS ON THE FORK IN THE TRANSFER CASE.
SOURCE: 4wd makes loud noise, also pops out of 4wd
Sounds "used and abused"!!! Likely you have more than one problem. Transfer case may need linkage adjustment or rebuild. Grinding from where? Wherever the noise is, look for a problem. Pulling can be from any number of front end component failures. Your best bet is to give everything a careful inspection or have a reliable shop go over it for you. There are so many variables in this I couldn't possibly give you any real answers!!!
good luck!
SOURCE: 06 Jeep Wrangler making a loud clincking or grinding when turning
By any chance is the transfer case engaged?
A locked drive train could account for the noise being made only on turns.
Bring the transfer case to neutral then back to 2-high.
Or try to duplicate the problem by putting it into 4-high. THAT way the dealership would know exactly what to look at.
BEST REGARDS
Mike
SOURCE: My jeep wont move in any gear
If your transmission is low on fluid it won't move the vehicle. Sounds like you had just enough fluid to get first gear going.
