Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Feb 01, 2009
In need of a picture of the on/off switch for Dyson DC17.
I removed the switch assembly on my Dyson DC17 Animal and there is a little white plastic ''widget'' that fell on the floor along with the ''buttons'' that you push to turn on/off the power and the floor brush. I can not figure out how to put the little white plastic piece and spring back together.
HELP!!!!!!
Thanks in advance!
  • dysonvacuum Apr 08, 2009
    Same thing!!!
  • Thomas S Powers
    Thomas S Powers Jun 06, 2017
    does not show second spring position ? Anyone know where roller brush button spring is positioned
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
23386
Points
93
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
In need of a picture of the on/off switch for Dyso - 62eaed7.jpg
  • 3 more comments
  • GES12 Aug 29, 2011
    This was most helpful. Disassembling the switch is just full of surprises with springs and spring loaded parts flying in all directions. No time to take a picture especially with the clarity of the one above. Thanks Greg Schuster
  • Anonymous Apr 04, 2012
    I actually fixed the placement of that little white thing, which was the problem, not the switch asseembly, and followed the photos to put the thing back together. It is working!! I'm so pleased, 72 year old woman with Parkinson's! It only took a week..Thanks,,,,Adeline Evans
  • Anonymous Mar 14, 2013
    The pictures aren't showing up for me. Can you please repost? Thank you!
  • Benjamin Frey
    Benjamin Frey May 08, 2014
    on the top picture is the spring missing that holds the little white thing back.
  • Sam Raymer
    Sam Raymer Oct 05, 2017
    I ended up leaving the white thing out, as I couldn't figure out where the 2nd spring went, and it kept falling out. It made no difference, buttons work fine!
Removing dyson dc 17 brush bar housing assembly
There are plastic clips that you will have to remove, then pull on one side of the assembly to remove it then pull on the other side.
Dyson 07 wand cap removal
http://www.dyson.com/support/dc17/dc17-animal/diagnosis-root-menu/dc17filterwashvid/flo-dc17-wand-suction/flo-dc17-remove-the-wand-from-hose - This should help you!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
My carpet nap is very thick and it is very hard to vacuum with my Dyson dc17 animal. I need to know if there is a way to adjust the height on the vacuum
Hi Deb,
I'm sorry to hear you're having difficulty using DC17 on this particular carpet type. DC17 is engineered to adjust automatically to different floor types, and does not need manual height adjustment.
Carpet manufacturers sometimes recommend vacuuming deep or delicate carpet piles with the rotating brush bar turned off. We'd recommend checking with the manufacturer of your carpeting as they'll be best placed to offer advice on the correct way of cleaning it. To turn off the brush bar on DC17, just use the silver brush control switch next to the red on/off switch.
It's also worth checking that the soleplate is fitted correctly. Any dirt or residue on the soleplate can be removed with a damp cloth - make sure it's completely dry before refitting it. You can find out how to remove and replace it here: http://content.dyson.com/support/help.asp?article=962&product=DC17-ANIMAL
I hope this helps, but if you would like further advice after you've given this a try, please email your details to [email protected]. One of our experts will be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
1helpful
I need assembly instructions for my Dyson dc17 vacuum -
I was able to find a link to the owners manual for your Dyson DC17 upright, and I have added the link below. I have checked the manual yet, but this should explain to you how to assemble your Dyson. If for any reason it doesn't, or you'd like me to further help you, please don't hesitate to add a comment to this repair page, and I'll be more then happy to walk you through it.
Owners Manual For Dyson DC17:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
1helpful
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
