Question about LeapFrog Leapster Explorer Learning Game System (green)
Daughter leapstergs want charge with adapter - LeapFrog Leapster Explorer Learning Game System (green)
Plug it harder and it charges your datuers leapstergs.
Posted on Jan 12, 2014
SOURCE:
Leapster GS screen upside down
I would try resetting it. You could also try calibrating the screen. The GS screen has a static orientation, so this seems like a very odd problem.
Leapster Explorer or LeapsterGS Explorer screen is not responding to the...
Aug 16, 2013 | Toys
Low battery indicator
Have the battery checked first as it may not be connected properly or may be no good and not accepting a charge IF you run the machine off the adaptor it probably will not be charging the battery so I suggest you plug in the adaptor and leave the machine off for a few hours to see if the battery will charge.
Jun 04, 2013 | LeapFrog Toys
Daughter changed password on acer one 200 given to her by granddmother and now cannot open screen
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 02, 2013 | Acer Ferrari ONE 200-1799 Notebook
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Fisher price dvd player - Need instruction manual
Check the Fisher Price website for an instruction manual. My daughter has one and when you plug it in and the red light is blinking that means the battery is charging. It has a battery pack inside (not removeable) that needs to be charged for 8 hours before the first use, but I'm guessing yours is used, so just let it charge until the light goes off.
Jun 10, 2009 | Televison & Video
Will not turn on
Check the adapter with a multi-meter, the voltage on the connector plug should be slightly higher than the voltage that is printed on the label attached to the adapter.
OR
Borrow a working adapter, make sure it is the same or compatible to test your laptop.
Apr 14, 2009 | Gateway Computers & Internet
Charging my ipod 3rd generation
To charge the ipod you can plug it into the computer using the usb cable it should have came with or you can plug it up to a power adapter such as an ihome stereo system
Jun 01, 2008 | Apple iPod nano 3rd Generation
Toshiba M15-S405 Battery Won't Charge
hello,by anoteher charger,you`r capacitor on charger is poor.best solution for you is to by a new charger,that is 100
Mar 03, 2008 | Dell Inspiron B130 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
LeapFrog Leapster Explorer Learning Game System (green) Logo
52 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
