Based on the symptoms you have described, it's possible that there may be an issue with the ballast or the lamp in your Sunquest Pro 24 tanning bed.
Here are some steps you can take to troubleshoot the issue:
Check the power source: Ensure that the tanning bed is plugged into a working electrical outlet and that the outlet is supplying the correct voltage. You can use a voltage tester to check the voltage.
Check the ballast: The ballast is a device that regulates the electrical current to the lamp. If the ballast is faulty, it may prevent the lamp from lighting up. Check the ballast for any visible damage or loose connections. If you're comfortable with electronics, you can also use a multimeter to check the ballast's continuity.
Check the lamp: If the ballast is functioning correctly, the issue may be with the lamp. Check the lamp for any visible damage or dark spots. You can also use a continuity tester to check the lamp's continuity.
Check the timer: If the timer is not functioning correctly, it may prevent the tanning bed from turning on or lighting up. Check the timer for any damage or loose connections.
If you're unable to identify the issue, it's best to contact a qualified technician or the manufacturer's customer service for further assistance. Tanning beds use high-voltage electrical components that can be dangerous if mishandled, so it's important to take proper precautions and not attempt to repair the tanning bed yourself unless you're experienced with electronics.
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
