Message says remove paper standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
SOURCE: The screen reads remove paper standard bin. We
if your getting a standard bin error this is caused by the flag on the top of the printer where the paper comes out or the sensor that it triggers. look to the far left where the paper comes out you'll see the flag make sure it moves freely if it does replace the sensor
SOURCE: error message says: remove paper from standard
Make sure that the exit flag is moving freely. It sounds like it is stuck in the up position or popped out of place. The flag is located on the left side of the output bin and should be hanging down
Testimonial: "Thanks, great information. "
SOURCE: Our Lexmark E352dn printer displays a 'REMOVE
Here's an article in the Lexmark website to guide you on what to do when having that error message on the printer. Just click on this link: http://bit.ly/a4odfK . It has some images to better understand the instructions.
SOURCE: MESSAGE ON THE SCREEN IS:
Here's an article in the Lexmark website on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/do0N3V. Read thoroughly and follow the instructions. Hope this helps. But if problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
SOURCE: remove paper from standard output bin there no
Maybe the paper exit guide is stuck or loose. Here's an article on A "Remove Paper - Standard Bin" or a "Std Bin Full error" Is Appearing on an E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aygJz1. Follow the instructions. Thanks
