SOURCE: Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
SOURCE: DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input on your TV
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
