When machine gets to rinse cycle water leaks through detergent tray. What I noticed was that there was quite a lot of water in the machine and it then it started spinning rapidly and then water leaked out. It doesn't leak on filling up at the start
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
This video will show you how to find that leak on any front
loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
I have exactly the same problem
Removed €18 in small change from the filter !!! I must say it's a ridiculuous place to hide a filter,Thanks very much for the solution, Machine back earning its keep again, and I'm €18 better off also
Hotpoint Ultima WF860 leaks water from the soap drawer twice while rinse and spin.. a lot of water
water leaks from under machine
