Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Bill Sims Posted on Feb 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
This also sometimes happens when tv is already on. tv suddenly goes blank & then red light flashes six times
Edgardo Pinero
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 55 Answers
  • Posted on Feb 07, 2013
Edgardo Pinero
Expert
Level 2:
New Friend:
Night Owl:
Answers
55
Questions
0
Helped
8794
Points
138
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVwhen turning on tv. screen will display Bravia ima - icon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
3 Related Answers
Anonymous
  • 25 Answers
  • Posted on Jan 29, 2010
SOURCE: TV does not turn ON
Sounds like a power supply issue. order a new power supply or trouble-shoot the current. Look for any capacitors that are bulged up on the top and not flat.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Dec 18, 2010
SOURCE: My Sony Bravia KDL-46XBR4 screen
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL46XBR4
Above is your user manual and support site, to download.
http://72.9.159.100/avs-vb/showthread.php?t=1261602
Worth a look at above, Hmmm??
http://www.eserviceinfo.com/index.php?what=search2&searchstring=sony+kdl-46xbr4
Above is your service and repair manual for download.
What is happening is there is an internal "Fault" that is causing the Protection Circuitry , to detect the problem, and attempt to shut down the set. When we keep restarting the set, it may work briefly again, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Sony, in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Sep 27, 2011
SOURCE: Sony BRAVIA KDL-46V3000 Television goes black
This issue is related to a power problem in as much as the TV turns off on it's own. I think the TV has developed a power problem.
The problem is consistent with overheating on the power supply board of the TV.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You can buy this part at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor (capacitors) most likely the normal operation will be restored. Or you can buy a refurbished complete GM1 power board from shopjimmy.com to save you some stress.
If this task is too technical for you, you can call a family or friend who has the ability to assist you (two heads are better than one).
My LED TV is showing a blank screen. How can I check my TVs backlight by using jumpers on the power board? I've seen videos to do this, but nothing specific to a similar Sony model.
put jumper in between pin no 23 & 28 now your power supply is on but still no voltage at led out put error 6 code is particular for led out put not for t con so please replace power board complete
Sony bravia KDL-46EX725 6 flashing red light
Check the power supply. IT might have bad caps.
I have sony bravia kdl-40x2000 which: turns on and the power indicator light stays green (no flashing red light codes) has no picture has no images seen even using a strong flashlight has sound from the...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
8helpful
2answers
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
2helpful
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
[email protected]
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
