Question about Nikon D60 Digital Camera
I droped my D60 and it will not come on as if it had no power charged the bat. but did not help
    Novelist:
  • Nikon Expert
  • 357 Answers
This is a hard one to answer as there can be all sorts of causes for this. Flexes can come out of their connectors. Flexes can be damaged. Depending upon where it hit, you could have shorted out the flash and blown the main circuit. What you need to do is carefully remove the bottom and back covers (careful - the back cover is connected to the main circuit by a flex!!!) and check the flexes and make sure they are seated properly. Then check the boards for impact damage. For more than this you should probably seek professional help, as there are boards in the front, top, and side that contain 300 volts for the flash and you can get a nasty shock if you do not discharge the flash capacitor using a 100 ohm 5 watt resister tool
Posted on Feb 02, 2013
SOURCE:
Charging problem
Hi
As the battery & regulator/rectifier have been replaced, the only other things to check are :-
Continuity from reg/rect red wire to battery & to earth, then check for continuity between each of the 3 yellow wires, all should be the same resistance - if not the stator coils in the alternator are faulty
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
May 06, 2010 | 2006 Yamaha V Star Classic
Red bat light on flashing pwr sply pluged in bat status says 9%/214hrs this does not decrease and bat does not seem to charge
Your power supplies voltage is incorect and the adapter should be replaced. It may be supplying enough power to run the system but not to charge. Cheap replacements on ebay. Good Luck.
Nov 24, 2009 | Dell Latitude D610 Notebook
Will the carama charge while plugged into the
No it will not charge.To get a reliable charge remove battery and use supplied charger
Jul 18, 2009 | Nikon D60 Digital Camera
Jet3 ultra power chair wont charge
If you have access to a voltmeter,put it on your battery then plug in the charger; if the voltage rises that will tell you that your charger is working.
Apr 09, 2009 | Jet 3 Ultra Power Chair
Built-in flash not working
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Apr 03, 2017 | Nikon D60 Digital Camera with 18-55mm lens
Alternator not delievering a charge
Trace the wire from the alternator to battery for a fusable link, might be burnt. Not knowing what year your truck is, I don't know if your truck has the external voltage regulator which is usually mounted on the inner fender well, or if it's built in the alternator.If it does have the external one try replacing it. Hope this helps.
Jan 23, 2009 | 1983 Ford F 250
Nikon D60 won't turn on
I thought the battery charged via the USB cord. It has to be charged only via the wall charger. Problem solved. I'm just a dummy!
Nov 22, 2008 | Cameras
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
Nikon D60 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
