Question about Panasonic DVD-A110 DVD Player
Sony dvp sr750h dvd player saying tray locked
Manual says take to sony dealer .
3 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
SOURCE: We have not used our DVD player in a couple of
On the bottom of the DVD player is a little slot where you can use a small screwdriver and unlock the cd tray.
Posted on Nov 08, 2009
Sony dvd player dvp-sr750h
Hello
What is the problem with your Sony DVD player?
Feb 27, 2012 | Televison & Video
Can you tell me how to unlock the region code for a Sony DVP-SR750H dvd player?
hi to hack the sony dvp-760h turn it on and press 12450 . it should now play all region. as mine does. :-) happy days
Jan 20, 2012 | Televison & Video
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
Jul 26, 2010 | Sony DVP-NS315 DVD Player
SOny DVD Player DVP-NS50P Locked
press stand by and press return button and enter button and then press stand by button on ur remote control.the player will be unlocked
Dec 27, 2009 | Sony DVP-NS50P DVD Player
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Sony DVP-NS700P DVD Player
SONY DVP NS5OP is LOCKED
probably you locked it mistakenly, what you should do leave the player in standby, press RETURN, ENTER and then POWER buttom again. watch a nice movies.
Feb 07, 2008 | Sony DVP-NS50P DVD Player
Panasonic DVD-A110 DVD Player Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
