After installing new worm gear, etc. motor works fine in clockwise direction, but does not reverse. RPM sensor is on and there is no play in the gear. The contact on the limit switch assembly is reached and any further attempts to get the motor to work result in clicks only.
SOURCE: Replace liftmaster 1245R drive/worm gear
Look at another web re how to replace a stripped gear of a garage door opener. Look at "galtrying" concerns. I have posted a quote on how I did mine with motor out. Easy as a piece of cake.
SOURCE: replaced sprocket and worm gear on chamberlain 1/2 opener
CHECK THE RPM SENSOR A LITTLE CUP ON THE MOTOR SHAFT. IF IT IS NOT INSTALLED SO THAT IT INTERUPTS THE SENSOR THE OPENER WILL GO 6-8 INCHES AND STOP.(AND BLINK 5 TIMES)
ONCE YOU GET THE LITTLE WHITE CUP PROPERLY ALIGNED YOU WILL NEED TO RESET YOUR TRAVEL LIMITS AND TEST YOUR REVERSE / SENSITIVITY SETTINGS.
HOPE THIS HELPS
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
where is trolley assembly. up against bolt?
