I get an alert window that tell me I need NET framework 2.0 and it has a link, but I cant find it. I fine service packs and redistribution but cant fine a plain 2.0 version.
SOURCE: I bought a lexmark x2580
the file that is missing in your computer is required to load the Lexmark Imaging Studio . and you have to load that file in your pc through windows installation cd. it will then work properly for sure. if it is not possible for you to load then call local computer engineer at your place he will load it for you.and charge not more than $5.it will take not more than 15 minites to complete the process.simple solution enjoy.thanks. keep me updated.
SOURCE: Erors when attempting to install kodak printer
open explore go C:\WINDOWS\Microsoft.NET\Framework rename v2.0.50727 to v2.50727_old then try it. it work for me and i loaded the easyshare software after with no problems.
SOURCE: ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
Testimonial: "ALMOST INSTANT RESPONSE. VERY HELPFUL ADVICE. THANKS SO MUCH."
SOURCE: I installed the lexmark 4650 All-in-one wireless.
You can try to uninstall .net framework by using .net framework uninstaller and then try to install .net framework 3.0 or above
You can also use the following link:
http://support.microsoft.com/kb/908077
