Question about Canon MV650i Mini DV Digital Camcorder
Battery pack use
My camcorder works with power but when i install battery pack it doesnt work, i have the same problem. i wondered if it was because i let it charge for too long. everything had been fine till then and now that battery is fully charged but won't power the camera and neither will any other battery. there isn't any build-up - everything's super-clean.
any other ideas?????
I have a similar problem. My MV650i works from the mains power but not from the battery even though I have tried new battery packs.
Posted on Jul 19, 2009
SOURCE:
Sony Touch Screen in camcorder hc26 do not work. thanks
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 28, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Hi having problem setting date ,month ,time on camcorder . The touchscreen is not working when i press against screen
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
Feb 22, 2011 | Sony Handycam DCR-HC20 Mini DV Digital...
TOUCH SCREEN DOESN'T WORK TO PLAY VIDEO
Jan 27, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
MY SONY CAMCORDER DCR-HC20 TOUCH SCREEN IS NOT WORKING
Jan 15, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
I went to charge my canon FS100 camcorder than went to turn it on and it not working now what can be the problem?
have the same prob this morning, check the charging unit for the serial no. (will begin with CA) mine is CA590E, the 590 is a known problem to cannon, it will either discharge the battery pack (pray this is the fault) or it will internally damage the camcorder. mine is only 18 months old used a max of maybe 10 times. I will reply again this afternoon when i've tried a new battery charger, just waiting for my cannon dealer to open.
Mar 01, 2010 | Canon FS100 Flash Media Camcorder
Canon FS 200 battery pack communication problem warning-BP 808 ba
You may want toget a battery that "New Canon BP-808 Equivalent Li-Ion Rechargeable Battery. Rated with 900mAh, the battery is made with info-chip, which can show remaining time on camcorder LCD. It also can be charged by Canon original charger and camcorder. It works wonderfully for and is 100% compatible with:
Feb 13, 2010 | Canon FS200 Flash Media Camcorder
Battery pack use
Have you charged your battery?
Your battery may need to be replaced. Radio Shack carries them for about $20 - $30 a piece depending on how long the life is in them.
I carry a few for my camcorder just for that reason. Then you will have a backup source.
Jun 15, 2008 | Canon ZR80 Mini DV Digital Camcorder
Power problem
Hi, replace the battery pack
Jan 24, 2008 | Sony DCR-DVD301 DVD Camcorder
Canon MV650i Mini DV Digital Camcorder Logo
118 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
